I use a panel data set. I need to copy some value from cross-section AA to another cross-section AB, but not to any other cross-sections.
So far, I create an auxiliary series TEMP, copy the value from AA to TEMP. However, when I want to copy TEMP to AB it does not work as for the corresponding sample (AB), the series TEMP contains only NAs.
Copy values from cross-section to entire vector
Re: Copy values from cross-section to entire vector
Can you be a bit more specific about what you are doing? What values in AA need to be copied? Is it the value for one date, or values for a range of dates? Are we matching up observations by-date?
I have created a workfile and a codefile which does the required task. However, I assume this approach is way too complicated for what I require.
- example.wf1
- (12.29 KiB) Downloaded 404 times
- example.prg
- (275 Bytes) Downloaded 414 times
series var2a = @meansby(var2, country, date)Who is online
