Rolling regression error message
Aktar
Postby Aktar » Wed Feb 21, 2018 9:05 am
Hi;
Im trying to run a roll regression from the existing object eq01 (object roll01) but Im getting a message error (see the attached files).
The message is : _RSES02_NEER_SEYCHELLES01 is not defined.
Are there any solutions ?
Thank you
erpt_estim.wf1
(333.62 KiB) Downloaded 941 times
Re: Rolling regression error message
Postby EViews Gareth » Wed Feb 21, 2018 9:07 am
EViews does not have rolling regression built in.
Aktar
Postby Aktar » Wed Feb 21, 2018 10:12 am
I added the add-in roll
Postby EViews Gareth » Wed Feb 21, 2018 10:19 am
What did you do?
Aktar
Postby Aktar » Wed Feb 21, 2018 3:45 pm
I added the add-in, runned an ols model and saved the object (see eq01), created a new object "roll" and selected the equation object for the rolling regression (fixed window ; step size1 ; window size = 47; start and last dates are the sames as the sample).
I didnt get the message for almost all models (cpi_xx c neer_xx price_xx), but for some countries, the neer_xx variable seems to get the estimation to crash although the variables seems fully normal.
Im getting the same message whatever I use an existing object or an equation entered manually.
Postby EViews Gareth » Thu Feb 22, 2018 8:48 am
It sounds like you're using the roll user object, not the rolling regression add-in? You might be better off using the add-in.
Aktar
Postby Aktar » Fri Feb 23, 2018 12:46 am
Yes, but i get the same bugs see the enclosed files.
I don't understand: when i replaced ar(1) by the lagged variable (ie cpi_xx(-1)) i got the bug... with the add-and the object... Is there a problem of sample size?
Aktar
Postby Aktar » Fri Feb 23, 2018 1:34 am
ok it seems that the bug is coming from the character number of the variable label... reducing it makes the add-in working :s
Return to “Add-in Support”
