Hello.
how can I test correlation in a simultaneous Model , the Method I use is TSLS. I noticed that I can't use "AR" , it gives an error message as "AR is not defined".
correlation test for TSLS method
Re: correlation test for TSLS method
The section "How to Create and Specify a System" of the "System Estimation" chapter of User Guide II gives pretty clear instructions on how to add AR terms to a system.
thank you very much for your help.The section "How to Create and Specify a System" of the "System Estimation" chapter of User Guide II gives pretty clear instructions on how to add AR terms to a system.
