correlation test for TSLS method
key23
Postby key23 » Thu Jan 21, 2010 7:26 am
Hello.
how can I test correlation in a simultaneous Model , the Method I use is TSLS. I noticed that I can't use "AR" , it gives an error message as "AR is not defined".
Re: correlation test for TSLS method
Postby EViews Gareth » Thu Jan 21, 2010 9:14 am
The section "How to Create and Specify a System" of the "System Estimation" chapter of User Guide II gives pretty clear instructions on how to add AR terms to a system.
key23
Postby key23 » Thu Jan 21, 2010 10:01 am
thank you very much for your help.
