Syntax Error
Seun123
Syntax Error
Postby Seun123 » Sat Apr 01, 2017 6:03 am
When I attempt to generate the series LD C LE LE(-1) LD(-1) @TREND I keep getting the error message "syntax error".
I have tried to generate a range of different series such as LD C LE or RR C RL and I am still getting the same message. I was not having this problem when I generated eq01.
I have attached a copy of my file. If anyone could offer any insight I would be grateful.
I am using the student version of Eviews 9.
shiller 16 eviews.wf1
(45.2 KiB) Downloaded 228 times
Re: Syntax Error
Postby EViews Gareth » Sat Apr 01, 2017 7:25 am
I don't understand what you're trying to do. Are you trying to create a new series, or estimate an equation?
