When I attempt to generate the series LD C LE LE(-1) LD(-1) @TREND I keep getting the error message "syntax error".
I have tried to generate a range of different series such as LD C LE or RR C RL and I am still getting the same message. I was not having this problem when I generated eq01.
I have attached a copy of my file. If anyone could offer any insight I would be grateful.
I am using the student version of Eviews 9.
Syntax Error
Syntax Error
- shiller 16 eviews.wf1
- (45.2 KiB) Downloaded 229 times
Re: Syntax Error
I don't understand what you're trying to do. Are you trying to create a new series, or estimate an equation?
