Problem in forecasting with dynamic model
UmBert
Postby UmBert » Thu Aug 11, 2016 9:12 am
I have a problem in forecasting with my dynamic model (dyn_fin) in the workfile. I have estimated my model with the dataset from 1978q1 to 2014q2 and now I want to estimate the "virtual future" from 2014q3 to 2016q2 for the variable PCI. When I try to do this I get only one point of forecast due to the adjustment of the sample (static and dynamic forecast as well). I can't understand why there is an adjustment because I don't have any missing data and with another similar workfile I do not have this problem.
Am I making a mistake?
Can someone help me to find the way to get my forecast with the right sample?
project.WF1
(107.95 KiB) Downloaded 251 times
Re: Problem in forecasting with dynamic model
Postby EViews Gareth » Thu Aug 11, 2016 9:26 am
You don't have data for all of your regressors over the forecast period.
UmBert
Postby UmBert » Thu Aug 11, 2016 9:33 am
No, this is not true. My dataset is complete until 2016q2.
Look at the attached screenshot.
Postby EViews Gareth » Thu Aug 11, 2016 10:25 am
Looks at the regressors.
UmBert
Postby UmBert » Thu Aug 11, 2016 10:48 am
Can you suggest me the path to check for this because I don't know where to go.
Postby EViews Gareth » Thu Aug 11, 2016 11:43 am
For each regressor that you specified in the equation, look at the series and check if it has data
UmBert
Postby UmBert » Fri Aug 12, 2016 12:44 am
I have checked each regressor and for each series I have the data until 2016q2 so this cannot be the problem. There are not any missing data in the whole series.
Postby EViews Gareth » Fri Aug 12, 2016 8:10 am
I suggest you look harder.
UmBert
Postby UmBert » Wed Aug 24, 2016 2:41 am
OK...but in order to have the the missing data, I have to make a regression. If I made the regression, the forecast would be useless. This restriction on EView for what concerns forecasting makes the application totally useless...if you have the data, why forecasting?
Postby startz » Wed Aug 24, 2016 6:02 am
This has nothing to do with EViews. It is a fundamental issue with forecasting. You either need a model in which you know the future value of the right hand side variables or you need to build an auxiliary model to forecast those right hand side variables.
