Automatic ARIMA forecasting
ESVAL2016
Postby ESVAL2016 » Fri Mar 11, 2016 5:13 am
Good evening, for all
I want to use "Automatic ARIMA forecasting" in EViews9, and I am dealing with two-time series, one of them is non-stationary its represent the endogenous variable(Y), and another one its stationary series and its represent the exogenous variable(X), OK.
My problem is:
When I applied "Automatic ARIMA forecasting", to perform this model, I observed the non-stationary series not transformed to be stationary series for example(DY)!!
How to solve this problem in EViews programme?
Best Regards,
ESVAL2016
Re: Automatic ARIMA forecasting
Postby ESVAL2016 » Wed Mar 16, 2016 5:31 am
Hello, for all
Why are there a big difference in the result in Automatic ARIMA forecasting AND estimate equation !!? Which method is the right way??
Thanks for your help.
Postby EViews Gareth » Wed Mar 16, 2016 6:37 am
There should not be big differences.
ESVAL2016
Postby ESVAL2016 » Wed Mar 16, 2016 4:31 pm
For example,
My model (1,1,0)(1,0,1)12 by estimate equation, I have AIC = 7.347764 AND R^2 =38%
The same model by Automatic ARIMA forecasting, I have AIC= 7.500708 AND R^2=94%
I think its big difference !!
Postby EViews Gareth » Wed Mar 16, 2016 4:36 pm
Was the same sample used? Automatic forecasting will drop more observations, usually.
ESVAL2016
Postby ESVAL2016 » Thu Mar 17, 2016 6:19 pm
Yes, I used the same sample in both methods !!
Also, Automatic ARIMA doesn't transform my non-stationary series !!
Therefore,
I think estimate equation box is the best way to find the better model
What is your opinion?
Postby EViews Gareth » Thu Mar 17, 2016 6:46 pm
I doubt the same sample was used for estimation of the chosen model. Check the output carefully.
ESVAL2016
Postby ESVAL2016 » Fri Mar 18, 2016 6:02 am
Only, one difference in the work, I take the first difference of my original series. Because the automatic way is not transformed the non-stationary series !!
Estimate Equation.PNG (33.68 KiB) Viewed 9739 times
Automatic ARIMA.PNG (33.26 KiB) Viewed 9739 times
ESVAL2016
Postby ESVAL2016 » Fri Mar 18, 2016 8:17 am
Which way is the right way to find the best model??
Equation output for Automatic ARIMA.PNG (36.46 KiB) Viewed 9731 times
Postby EViews Gareth » Fri Mar 18, 2016 9:30 am
Not really sure what the issue is.
If you believe the series should be differenced, difference it and then use the automatic arima selection.
If you believe the series should be differenced and follows an exact arima specification, then use that specification and don't use the automatic selection.
