Dear all,
after getting the results from TAR and MTAR estimation, how can I tell eviews to estimate an AECM?
I read the other discussion but i didn't find the description of the code...
Thank You in advance,
bests
AECM
EViews Rebecca
Re: AECM
In what context are you trying to estimate an AECM?
EViews Rebecca
Re: AECM
It will help me point you in the right direction if I know what you are trying to accomplish.
Re: AECM
Hi Rebecca,
sure, thank you. I estimated a (Consistent)M-TAR model for two prices (and 5 exogenous variables, one shift dummy and four impulses) and results indicate the existence af asymmetries and cointegration between the two series. Now, I'd like to estimate the AECM (relative to the MTAR) in order to investigate short run dynamics, but I don't know how to generate positive and negative ECT. In case this would be possible, the next question would be how to display IRFs for positive and negative shocks, in order to show the asymmetric adjustment.
I attached the workfile for if it could be of any help. "mtarcons" is the model to which I refer.
Thanks in advance,
bests
Thanks in advance,
bests
- work1.WF1
- (38.89 KiB) Downloaded 601 times
EViews Rebecca
Re: AECM
What you're asking goes beyond our normal help. Did you produce your current results using the TARCOINT add-in? If so I suggest going to the add-in section of the forum and asking your question there.
