AECM
anto2209
AECM
Postby anto2209 » Fri Mar 04, 2016 9:02 am
Dear all,
after getting the results from TAR and MTAR estimation, how can I tell eviews to estimate an AECM?
I read the other discussion but i didn't find the description of the code...
Thank You in advance,
bests
EViews Rebecca
Re: AECM
Postby EViews Rebecca » Fri Mar 04, 2016 11:50 am
In what context are you trying to estimate an AECM?
anto2209
Re: AECM
Postby anto2209 » Wed Mar 09, 2016 10:12 am
Dear Rebecca,
first of all thank you for your reply.
I'm not sure to understand what you mean with in which context..
Thank you again,
Federico
EViews Rebecca
Re: AECM
Postby EViews Rebecca » Wed Mar 09, 2016 12:37 pm
It will help me point you in the right direction if I know what you are trying to accomplish.
anto2209
Re: AECM
Postby anto2209 » Thu Mar 10, 2016 3:22 am
Hi Rebecca,
sure, thank you. I estimated a (Consistent)M-TAR model for two prices (and 5 exogenous variables, one shift dummy and four impulses) and results indicate the existence af asymmetries and cointegration between the two series. Now, I'd like to estimate the AECM (relative to the MTAR) in order to investigate short run dynamics, but I don't know how to generate positive and negative ECT. In case this would be possible, the next question would be how to display IRFs for positive and negative shocks, in order to show the asymmetric adjustment.
I attached the workfile for if it could be of any help. "mtarcons" is the model to which I refer.
Thanks in advance,
bests
work1.WF1
(38.89 KiB) Downloaded 601 times
EViews Rebecca
Re: AECM
Postby EViews Rebecca » Mon Mar 14, 2016 5:20 pm
What you're asking goes beyond our normal help. Did you produce your current results using the TARCOINT add-in? If so I suggest going to the add-in section of the forum and asking your question there.
anto2209
Re: AECM
Postby anto2209 » Tue Mar 15, 2016 3:45 am
Thank you Rebecca,
I posted the same questions in the Add-in section.
Bests
F
