BVAR
olsisthebest
BVAR
Postby olsisthebest » Wed Jan 13, 2016 4:49 am
It is possible to impose restrictions in the parameters, as in SVAR, in a BVAR estimation?
I mean, how can I estimate a SBVAR in EViews 9?
Thank you.
Re: BVAR
Postby EViews Gareth » Wed Jan 13, 2016 7:38 am
No
olsisthebest
Re: BVAR
Postby olsisthebest » Thu Jan 14, 2016 3:22 am
What are the differences between Normal-Wishart and Sims-Zha Normal Wishart priors?
Thank you.
Re: BVAR
Postby EViews Gareth » Thu Jan 14, 2016 8:52 am
olsisthebest
Re: BVAR
Postby olsisthebest » Tue Jan 19, 2016 10:03 am
Can I impose diferent hiperparameter values across equations?
For instance, in equation 1 the dependent variable behaves like a random walk then I set mu=1, in equation 2 the dependent variable behaves like a white noise then set mu=0?
And the same for the other hyperparameters.
How can I do that?
Re: BVAR
Postby EViews Gareth » Tue Jan 19, 2016 11:02 am
No.
olsisthebest
Re: BVAR
Postby olsisthebest » Wed Jan 27, 2016 9:25 am
I am using Sims-Zha NW prior to estimate a BVAR model.
When I use growth rates I don't have any problem. However, when I use the same variables but in levels I get the error "Near singular matrix".
Do you have any idea what is going on?
Re: BVAR
Postby EViews Gareth » Wed Jan 27, 2016 9:26 am
Not without seeing it.
olsisthebest
Re: BVAR
Postby olsisthebest » Wed Jan 27, 2016 10:38 am
Please find attached the workfile.
I get the error message "near singular matrix" if i consider the variables in levels.
With growht rates (prefix "dl") I don't have any problem.
Any idea?
Thank you.
test.wf1
(19.05 KiB) Downloaded 205 times
olsisthebest
Re: BVAR
Postby olsisthebest » Mon Feb 01, 2016 3:14 am
Dear all,
Does anybody have an idea about the aforedmentioned problem?
Thank you.
Re: BVAR
Postby startz » Mon Feb 01, 2016 7:09 am
Is your version of EViews uptodate?
olsisthebest
Re: BVAR
Postby olsisthebest » Mon Feb 01, 2016 7:18 am
Yes it is.
Did you try to estimate the BVAR with Sims-Zha Normal Wishart priors with variables in levels?
Re: BVAR
Postby startz » Mon Feb 01, 2016 7:35 am
Oh. I had just done a regular VAR. That works fine. I can confirm the Bayesian VAR does not work...and that does seem weird.
olsisthebest
Re: BVAR
Postby olsisthebest » Mon Feb 01, 2016 7:44 am
Yes, it is really weird. It is suppose to work fine since it is not possible to have perfect multicollinearity.
Let's wait for forum moderation's insights.
Re: BVAR
Postby EViews Gareth » Mon Feb 01, 2016 9:13 am
Your hyperparameters are crazy, due to a bug in saving BVARs. We'll fix the bug, but in the meantime you'll need to re-specify the hyperparameters after opening the workfile.
