BVAR
olsisthebest
BVAR
It is possible to impose restrictions in the parameters, as in SVAR, in a BVAR estimation?
I mean, how can I estimate a SBVAR in EViews 9?
Thank you.
Thank you.
Re: BVAR
No
olsisthebest
Re: BVAR
What are the differences between Normal-Wishart and Sims-Zha Normal Wishart priors?
Thank you.
Thank you.
olsisthebest
Re: BVAR
Can I impose diferent hiperparameter values across equations?
For instance, in equation 1 the dependent variable behaves like a random walk then I set mu=1, in equation 2 the dependent variable behaves like a white noise then set mu=0?
And the same for the other hyperparameters.
How can I do that?
How can I do that?
Re: BVAR
No.
olsisthebest
Re: BVAR
I am using Sims-Zha NW prior to estimate a BVAR model.
When I use growth rates I don't have any problem. However, when I use the same variables but in levels I get the error "Near singular matrix".
Do you have any idea what is going on?
Re: BVAR
Not without seeing it.
olsisthebest
olsisthebest
Re: BVAR
Dear all,
Does anybody have an idea about the aforedmentioned problem?
Thank you.
Thank you.
olsisthebest
Re: BVAR
Yes it is.
Did you try to estimate the BVAR with Sims-Zha Normal Wishart priors with variables in levels?
olsisthebest
Re: BVAR
Yes, it is really weird. It is suppose to work fine since it is not possible to have perfect multicollinearity.
Let's wait for forum moderation's insights.
Re: BVAR
Your hyperparameters are crazy, due to a bug in saving BVARs. We'll fix the bug, but in the meantime you'll need to re-specify the hyperparameters after opening the workfile.
