Hi!
I'm importing a panel dataset from excel to eviews and then using the pageunstack command to obtain a time series for each variable and id (countries in my case).
The command works smoothly for all my variables except two that are equal to 0 for each country and year. In this case I get the following error:
"country is not a series in pageunstack country dateid @ x y"
where country is my id, dateid is my time variable and x and y are the two zero variables in question.
Is there a way to make eviews untack the series even if they are made of all zeroes? Unfortunately I cannot just drop the variables because I need them to perform some calculations.
Thanks a lot for your help!
pageunstack
Re: pageunstack
Could you provide the file?
Re: pageunstack
Sure.
The variables i'm having problems with are snyc_at4, snyc_at5 tnyc_at5.
Thanks a lot!
Thanks a lot!
- file.xlsx
- (58.15 KiB) Downloaded 280 times
Re: pageunstack
Works fine for me. What's the version and build date of your copy of EViews (Help->About EViews).
Re: pageunstack
I'm using eviews 8 build Jun 19 2013
Re: pageunstack
Update to the latest version of 8.
