Date Issues When Importing
fmantessof
Postby fmantessof » Fri Aug 14, 2015 12:57 pm
I cannot make Eviews recognize the date series . It reads the Excel file and try to open it is as an undated file. I tried to delete all the rows below the worksheet and the columns besides to clear them out, but it still does not recoginze....Help !!
Re: Date Issues When Importing
Postby EViews Gareth » Fri Aug 14, 2015 1:06 pm
Could you provide an example?
fmantessof
Postby fmantessof » Sat Aug 15, 2015 11:20 am
Please, see the screen shots attached. I selected to open a foreign data as workfile, it opened the data series, but it did not recognize the date column as dates and I cannot open the file as a data series only as a unstructured data.
Screenshot 2015-08-15 15.10.16.png (62.47 KiB) Viewed 51758 times
Screenshot 2015-08-15 15.10.34.png (65.81 KiB) Viewed 51758 times
fmantessof
Postby fmantessof » Sat Aug 15, 2015 11:22 am
SORRY I MISSED THE LAST ONE THAT SHOWED WHAT I MEANT
Screenshot 2015-08-15 15.11.32.png (69.21 KiB) Viewed 51757 times
Postby EViews Gareth » Sat Aug 15, 2015 2:36 pm
Can you provide the actual Excel file?
fmantessof
Postby fmantessof » Sat Aug 15, 2015 3:50 pm
This happens frequently in different type of files and I couldn't find a reason for this yet. I selected to send you a very simple file as an example of one of the cases this is happening
Pasta1.xlsx
(225.08 KiB) Downloaded 500 times
Postby EViews Gareth » Sat Aug 15, 2015 4:49 pm
That file doesn't contain a valid date series. If the Excel file doesn't contain a valid date series, EViews won't be able to select a date series.
fmantessof
Postby fmantessof » Sat Aug 15, 2015 6:04 pm
That's the issue, I know, but why is this a non valid date series ? This are date series downloaded directly from yahoo finance or google finance, what can I do as a process to find the error and fix it ? tks
fmantessof
Postby fmantessof » Sat Aug 15, 2015 6:21 pm
I found the mistake ! This data series came from Wiki and comparing to Yahoo's one there is some dates missing...I downloaded again and the series came again with the missing dates..tks
Postby EViews Gareth » Sat Aug 15, 2015 6:35 pm
Generally if EViews refuses to auto-recognize a date series it is because there is something wrong with that date series
fmantessof
Postby fmantessof » Sun Aug 16, 2015 4:54 am
Gareth, I tried with a file that seemed to be a correct data set, and it worked the same....This one is a direct download of BXP ticker from yahoo finance, see attached
Workbook3.xlsx
(324.77 KiB) Downloaded 520 times
fmantessof
Postby fmantessof » Sun Aug 16, 2015 5:15 am
Gareth, I found out what is going on...I use Quandl to download the data in Excel, however Quandl is delivering the dataset with missing dates both through Google and Yahoo
