log bug, or at least ungoodness
Postby startz » Tue Jun 16, 2015 8:06 am
Consider the following code sequence
series x=nrnd show log(x).hist series y=log(x) y.hist
hist on log(x) doesn't work, rather we get the log of nonpositive number alert and a spreadsheet. hist on y works fine.
Re: log bug, or at least ungoodness
Postby EViews Glenn » Tue Jun 16, 2015 9:42 am
Can't seem to replicate this bug...
Works interactively.
If I run it in a program with the default max of 1 error, I get the opened log(x) histogram and an error on the evaluation.
If I run it in a program and set the default max error to greater than 1, I get both opened windows.
If I run in silent mode I get no error, get both opened windows, and get an evaluation error message in a warning window.
Postby startz » Tue Jun 16, 2015 9:49 am
In this sort of case, I always recommend that the user update to the latest version of EViews :P
create u 100 series x=nrnd show log(x).hist
In interactive mode gives me the (correct) alert and then shows a spreadsheet rather than a histogram 100 percent of the time.
Postby EViews Glenn » Tue Jun 16, 2015 10:03 am
What setting do you have for auto-series evaluation on your latest version of EViews:
Options/General Options/Series and Alphas/Auto-series
Postby startz » Tue Jun 16, 2015 10:13 am
Report evaluation errors. I assume that's the default?
Postby EViews Gareth » Tue Jun 16, 2015 10:27 am
No.
Postby startz » Tue Jun 16, 2015 10:33 am
Well, that explains the different behavior.
Since NAs get generated properly either way, it would be nice if the alert were followed by the hist view rather than the spreadsheet view. Since the spreadsheet view is the default, I suppose that might be a pain. It's certainly not too important.
