How fill a series with a specific range of numbers
hirastikanah
Postby hirastikanah » Tue Jun 09, 2015 1:13 am
Hello
How can I fill a series without typing every single number?
For example :
I have a blank Series named a.
I can use the code a.fill 10,11,12,13,14,15
Is it possible to fill it somehow from 10 to 15 without typing the numbers one by one?
Thanks in advance
Re: How fill a series with a specific range of numbers
Postby EViews Glenn » Tue Jun 09, 2015 11:27 am
There are a variety of ways to do this depending on the exact values that you wish to use. The best method depends on the context. You'll have to provide exact details on your workfile structure, and the values you wish to use in initializing the series.
Postby EViews Gareth » Tue Jun 09, 2015 2:19 pm
Look up series.adjust in the object reference.
hirastikanah
Postby hirastikanah » Wed Jun 10, 2015 10:37 am
Hello again
Looking up for series.adjust didn't help.
I would like to fill a series with integer numbers start from 10 for instant to 15... Without typing them one by one 10,11,12,13,14,15
Postby EViews Glenn » Wed Jun 10, 2015 1:13 pm
series y = @trend+10
and if there are only 6 observations in the workfile
series y y.adjust = 10 .. 15 ^
The latter linear interpolates between the first observation and the last in the current sample using the endpoint values.
hirastikanah
Postby hirastikanah » Thu Jun 11, 2015 5:08 am
THANK YOU SO MUCH
one more question:
the workfile has 20 observations
to fill from the first one to the 6th one with numbers 10,11,12,13,14,15
series y=@trend+10 is great here but how can i stop it on sixth observation?
thanks again
Postby EViews Glenn » Thu Jun 11, 2015 10:58 am
Set a restricted sample
smpl @first @first+5 series y = @trend+10 smpl @all
hirastikanah
Postby hirastikanah » Thu Jun 11, 2015 11:59 pm
thaaaaaaaaaaaaaaaanks :D
