Hello
How can I fill a series without typing every single number?
For example :
I have a blank Series named a.
I can use the code a.fill 10,11,12,13,14,15
Is it possible to fill it somehow from 10 to 15 without typing the numbers one by one?
Thanks in advance
How fill a series with a specific range of numbers
hirastikanah
Re: How fill a series with a specific range of numbers
There are a variety of ways to do this depending on the exact values that you wish to use. The best method depends on the context. You'll have to provide exact details on your workfile structure, and the values you wish to use in initializing the series.
Look up series.adjust in the object reference.
hirastikanah
Hello again
Looking up for series.adjust didn't help.
I would like to fill a series with integer numbers start from 10 for instant to 15... Without typing them one by one 10,11,12,13,14,15
series y = @trend+10Code: Select all
series y
y.adjust = 10 .. 15 ^
hirastikanah
THANK YOU SO MUCHand if there are only 6 observations in the workfileCode: Select all
series y = @trend+10The latter linear interpolates between the first observation and the last in the current sample using the endpoint values.Code: Select all
series y y.adjust = 10 .. 15 ^
one more question:
the workfile has 20 observations
to fill from the first one to the 6th one with numbers 10,11,12,13,14,15
series y=@trend+10 is great here but how can i stop it on sixth observation?
thanks again
Set a restricted sample
smpl @first @first+5
smpl @all-
hirastikanah
thaaaaaaaaaaaaaaaanks :DSet a restricted sampleCode: Select all
smpl @first @first+5 series y = @trend+10 smpl @all
