Hello.
Say my original monthly time series ranges from 2000 to 2010.
The series is modelled are forecasts are made for months throughout 2011.
I plot the series on a chart and realize that the shape of curve for forecasted data aren't exactly what I want to get.
Is it possible with Eviews to display the line chart for the series and a vector for forecasted months where I could manually adjust the forecasted numbers? Chart must update automatically as I enter a new adjustment factor in the vector (this last point is essential).
Thank you for your suggestions.
Kinda IDE?
Re: Kinda IDE?
I'm not sure I fully understand what you're asking.
But, yes, it is possible to have charts that update as the underlying series changes.
eviewsuserforum
Re: Kinda IDE?
Thanks for the prompt reply.
Can you point to resources on these automatically updated charts, please?
Re: Kinda IDE?
If you look up "update" in the help system or manuals, you'll see an entry for Updating Graphs.
eviewsuserforum
Re: Kinda IDE?
Thank you for the reply. Updating charts is actually handy. Nice.
I would like to rephrase my initial query.
- I have a database with many monthly time series.
- I want it to be GUI-like. Programming is ok.
- I want my screen to be divided into 2 separate parts.
* Data (group object , spreadsheet)
* Chart
- I want the chart to update as a number is changed in the spreadsheet.
- The corresponding chart is displayed as I activate another column in the spreadsheet. I just want a single line on my chart.
- I need the data to be saved in the original eviews database as those 'manual adjustments' in the series are done ; I don't need the chart in the end.
- I add that the series I want to adjust manually are always the same in the group object (but the values are updated every 1 or 2 weeks; they are a mix of historical data and regression results).
Below is pic of what I am after (rougthly) : http://i.imgur.com/WaINPm0.png
Can you advise on where to start, please?
* Chart
Re: Kinda IDE?
That bit cannot be done. Everything else you describe is what updating graphs do.- I want the chart to update as a number is changed in the spreadsheet.
