Eviews crashes in subroutine
nupogodi
Postby nupogodi » Sat Mar 21, 2015 5:12 am
Eviews shuts down when calling non-existent subroutine.
In addition, the program just ignores calls to subroutines when the name of subroutine is long.
first_program_file.prg
include second_program_file call sub_exists
second_program_file.prg:
subroutine sub_exists call sub_doesnt_exist '<-- Calling non-existent subroutine endsub
Re: Eviews crashes in subroutine
Postby EViews Glenn » Sun Mar 22, 2015 6:59 pm
Thanks for the report. What version are you running? And what's the build-date?
nupogodi
Postby nupogodi » Mon Mar 23, 2015 12:32 am
v8.1 March 11 2015 build , Win 32 bit
Postby EViews Gareth » Mon Mar 23, 2015 8:12 am
Completely unable to replicate this.
I created the first_proram_file and second_program_file programs, then run the first one, and it just gives the error message of the subroutine not existing. No crash.
nupogodi
Postby nupogodi » Mon Mar 23, 2015 8:52 am
For me the program crashes every time on two different computers. Also after rebooting.
Postby EViews Gareth » Mon Mar 23, 2015 9:17 am
So you literally have those two .prg files. You open up EViews, open up first_program, click the Run button and then EViews crashes?
nupogodi
Postby nupogodi » Mon Mar 23, 2015 9:23 am
In order to replicate the error set default options:
1. Quiet (fast) no screen update
2. Maximum errors before halting 9999999
Postby EViews Gareth » Mon Mar 23, 2015 9:47 am
Ha, the maximum error count is what did it. We'll investigate. In the meantime, setting errors to 1 will cause it to not crash.
Postby EViews Gareth » Mon Mar 23, 2015 10:00 am
It will be fixed in the next patch.
nilslh
Postby nilslh » Thu May 03, 2018 2:17 am
I have a related problem using EViews 10+. When calling a subroutine within a subroutine, EViews occasionally crashes. The problem seems to be related to the number of maximum allowable errors. When setting the number manually to 100 (in EViews, via General Options) and in the subroutine to 1 (SetMaxErrs 1) I get a message that the number of maximum allowable errors has been exceeded. Then I remove the code snippet (SetMaxErrs 1) and run the program again and everything works well. Then I close EViews and run the program again, with the same options and without changing anything, and EViews crashes.
I am using Windows 10 and from the Event Viewer I got the information that the error arose from module "evCommon.dll". Not sure if that information is helpful.
Regards,
Nils
