HI,
Is there a way to retrieve the adjusted sample used in an equation?
Regards
Martin
Ajusted equation sample
Re: Ajusted equation sample
As a string? Or just being able to set the sample?
As a string, after the equation has been estimated. The {Equation}.@smpl-command only gives you the sample you set, not the adjusted sample.
Regards
Martin
Regards
Martin
The only place the adjusted sample string is available is in the output view. Other than that, the best you can do is to generate the residuals, and use them to construct your own adjusted sample string.
Ok, thanks!
Regards
Martin
Regards
Martin
What is the main reason for adjusted equation sample.
Some observations could not be used (usually due to NAs resulting from log of negative numbers), so the sample had to be adjusted.
