Ajusted equation sample
MOG
Postby MOG » Tue Feb 17, 2015 8:51 am
HI,
Is there a way to retrieve the adjusted sample used in an equation?
Regards
Martin
Re: Ajusted equation sample
Postby EViews Glenn » Tue Feb 17, 2015 10:57 am
As a string? Or just being able to set the sample?
MOG
Postby MOG » Wed Feb 18, 2015 12:12 am
As a string, after the equation has been estimated. The {Equation}.@smpl-command only gives you the sample you set, not the adjusted sample.
Regards
Martin
Postby EViews Glenn » Wed Feb 18, 2015 12:18 am
The only place the adjusted sample string is available is in the output view. Other than that, the best you can do is to generate the residuals, and use them to construct your own adjusted sample string.
MOG
Postby MOG » Wed Feb 18, 2015 12:28 am
Ok, thanks!
Regards
Martin
TELLA
Postby TELLA » Wed Jan 06, 2016 5:58 am
What is the main reason for adjusted equation sample.
Postby EViews Gareth » Wed Jan 06, 2016 8:55 am
Some observations could not be used (usually due to NAs resulting from log of negative numbers), so the sample had to be adjusted.
