Hi, is it possible to run a program and make Eviews to show a window to browse a file to open instead of typing file path in wfopen command? Concerning Eviews 7 or 8 soon.
adrian
Wfopen with opening browsing window
Re: Wfopen with opening browsing window
You can use the @uifiledlg command, which is documented in the Command and Programming Reference.
Sounds interesting, but I can't find it in any of the documentation, nor for Eviews 7 nor 8, no such a command there... Any closer hints?You can use the @uifiledlg command, which is documented in the Command and Programming Reference.
It is in EViews 8.1.
ok thanksIt is in EViews 8.1.
