Wfopen with opening browsing window
adrian_d
Postby adrian_d » Fri Jan 16, 2015 7:06 am
Hi, is it possible to run a program and make Eviews to show a window to browse a file to open instead of typing file path in wfopen command? Concerning Eviews 7 or 8 soon.
adrian
Re: Wfopen with opening browsing window
Postby EViews Gareth » Fri Jan 16, 2015 8:49 am
You can use the @uifiledlg command, which is documented in the Command and Programming Reference.
adrian_d
Postby adrian_d » Fri Jan 16, 2015 8:55 am
Sounds interesting, but I can't find it in any of the documentation, nor for Eviews 7 nor 8, no such a command there... Any closer hints?
Postby EViews Gareth » Fri Jan 16, 2015 9:06 am
It is in EViews 8.1.
adrian_d
Postby adrian_d » Fri Jan 16, 2015 9:15 am
ok thanks
