When importing data from Bloomberg, I occasionally get the following sort of error:
"Database Error: Bloomberg library error: 'The DateTime represented by the string is not supported in calendar System.Globalization.GregorianCalendar.' in "COPY(LINK) CURNCY::"KRW" KRW."
This happesn for eg KRW, BRL, and CLP, but not other currencies like CNY, EUR, JPY, MXN, etc. The page freq is d5. Has anybody else seen this error?
Thanks, and happy holidays!
bloomberg db import calendar error
- bbg calendar error.png (14.48 KiB) Viewed 6598 times
Re: bloomberg db import calendar error
What is the build date of your copy of EViews (help->about EViews)?
I am not able to replicate the problem.
I however used
whereby 'Bloomberg' is an entry in my EViews database registry (options->database registry).
I however used
copy(link) Bloomberg::"krw curncy" krwRe: bloomberg db import calendar error
25 nov 2014 is the build date
it is quite odd, because I get the same error when I drill down into the Bloomberg database via the browse function
it also refuses to download in any frequency of workfile
I wonder if I have the date setting in eviews somehow misconfigured?
thank you
thank you
- Capture.PNG (67.92 KiB) Viewed 6579 times
It should not matter and if it does we will fix it.
Select Options->general options and choose Date representation from the left side column. I have Month/Day/Year and Frequency delimiter set.
Hope you had a good holiday
Alas, changing the date representation doesn't change the outcome -- the same series come up with the same error message
Send an email to support@eviews.com with a reference to this forum topic. We will have to work offline to figure out what is going on.
The fix was added to the January 12 EViews 8.1 Patch. If you download the latest patch via help->EViews update and type 'regcomponents' and press the enter key into the command window, you should find the issue has been resolved.
