unit root test in quarterly data?
ANDROO1988
Postby ANDROO1988 » Sun May 25, 2014 5:16 am
hi
i have quarterly data
how can i do unit root test in quarterly data in eviews 8?
Re: unit root test in quarterly data?
Postby startz » Sun May 25, 2014 7:10 am
Have you looked at unit root test in the Help system?
ANDROO1988
Postby ANDROO1988 » Sun May 25, 2014 9:00 am
hi
i know unit root test in time series (annual data) is different with unit root test in quarterly data.
Postby startz » Sun May 25, 2014 9:31 am
Perhaps you could explain what you're thinking of in terms of annual and quarterly tests being different.
nishantvats12
Postby nishantvats12 » Sun Jun 15, 2014 1:05 pm
I presume you are talking about HEGY test. If that is the case you should consider referring to this post http://forums.eviews.com/viewtopic.php?t=301&f=15
