hi
i have quarterly data
how can i do unit root test in quarterly data in eviews 8?
unit root test in quarterly data?
Re: unit root test in quarterly data?
Have you looked at unit root test in the Help system?
ANDROO1988
hi
i know unit root test in time series (annual data) is different with unit root test in quarterly data.
Perhaps you could explain what you're thinking of in terms of annual and quarterly tests being different.
nishantvats12
I presume you are talking about HEGY test. If that is the case you should consider referring to this post http://forums.eviews.com/viewtopic.php?t=301&f=15
