Call EViews 8 (64 bit) from Matalb 2013a (64 bit)
Re: Call EViews 8 (64 bit) from Matalb 2013a (64 bit)
Postby EViews Steve » Tue Jun 03, 2014 3:59 pm
Wow, this one is difficult to figure out...
At best as I can determine, MATLAB seems to be remembering where the original type library was initially found for a given ProgID (in our case "EViews.Manager"). Once "remembered, MATLAB will continue to look for that file in the original location regardless of what the Windows registry is saying. This means that if the first time you wrote your MATLAB program you were using EViews 7, and then you upgraded to EViews 8 and uninstalled EViews 7, you would find that MATLAB is no longer working with EViews.
I haven't been able to figure out how to reset this cache (I've tried "clear all" and "rehash" without success) other than possibly uninstalling MATLAB, then re-installing it.
However, I did figure out an easy workaround. MATLAB only needs the EViews 7 file that contained the type library, which was: EViewsMgr.dll.
Actually, ignore this workaround -- I've figured out a better one -- see other postings below...
So I've made a modified public version of this file available for download. It needs to placed in the exact same location as where your previous EViews 7 installation was located. By default this location is:
(Windows 32-bit) c:\Program Files\EViews7 (note there is no space between "EViews" and "7")
(Windows 64-bit) c:\Program Files (x86)\EViews7 (note there is no space between "EViews" and "7")
Here's the download link for the modified file:
http://eviewsdropbox.s3.amazonaws.com/EViewsMgr.dll
Once you have this file in its original directory, you should be able to use EViews 8 via COM Automation from MATLAB 2013a.
If I ever figure out how to reset MATLAB, I'll post that too...
Last edited by EViews Steve on Wed Jun 04, 2014 11:56 am, edited 2 times in total.
Postby startz » Tue Jun 03, 2014 5:37 pm
Steve,
Have you contacted Matlab? Their tech support is generally quite good.
Postby EViews Steve » Wed Jun 04, 2014 9:53 am
I believe you need to have an active license with MathWorks before they will entertain any bug reports. We actually have an old license from 2009, but it's expired now.
I'm actually thinking it might be easier for me to modify the EViews 8 registration package and release this as a patch so that our MATLAB users can continue to use EViews COM. It'll probably be faster anyways...
Postby EViews Steve » Wed Jun 04, 2014 11:50 am
Ok I figured out a better workaround.
It turns out, MATLAB 2013 is always looking for version 1.0 of the type library for any given ProgID, even if you specify a different version to use (such as actxserver('EViews.Manager.8')). Without the 1.0 type library, MATLAB fails to load the Manager object correctly.
So I modified our EViews 8 installer to also include the type library file from EViews 7. When EViews 8 registers itself, it now also register's the type library file from EViews 7 just so MATLAB users can find it.
This fix will be in the new EViews 8 patch released sometime today or tomorrow.
Postby EViews Steve » Wed Jun 04, 2014 2:36 pm
Patch with this fix is now available. Within EViews, goto Help->EViews Update to get the latest patch. Or you can download and install it manually from our website: http://www.eviews.com/download/download.html
student07
Postby student07 » Fri Jun 06, 2014 11:43 am
Sorry for the late reply, but thanks a lot for your help! I really appreciate it. I will try out the new patch and see if that works. Thanks again.
student07
Postby student07 » Fri Jun 06, 2014 1:46 pm
The patch works! Thanks so much! One more question that I have now: is it possible to call a whole eviews program (.prg) from Matlab instead of running only single lines in quotes? If not, is it at least possible to paste a whole block of my eviews code in matlab without having to enclose every line in h.run(' ')? Thank you in advance.
Postby EViews Gareth » Fri Jun 06, 2014 2:21 pm
You can issue the EViews run command to run an entire program.
