Unable to Static Forecast GARCH model
ab00265
Postby ab00265 » Thu Apr 10, 2014 5:14 am
I've run a simple Garch model, and when performing static forecasts I receive an error saying "Unable to perform ARCH operation due to missing observations". I can however run dynamic forecasts fine, and static forecasts fine if the estimation method is OLS.
Does anybody know some possible causes of this?
Any help would be much appreciated!
Thank you
Andy
ab00265
Re: Unable to Static Forecast GARCH model
Postby ab00265 » Thu Apr 10, 2014 5:33 am
This attachment might help.
These are the fitted,actuals and residuals. From 2010M9 the fitted pretty much exactly match the actuals, so something is up here.
Postby EViews Gareth » Thu Apr 10, 2014 7:53 am
You probably have missing data over the forecast period.
ab00265
Postby ab00265 » Thu Apr 10, 2014 7:59 am
Thanks for your reply.
I have some blank sample space in order to make room for forecasts. And I am forcasting 1 step ahead, so I don't have data for this period.
Postby EViews Gareth » Thu Apr 10, 2014 8:35 am
Then you cannot perform a static forecast.
ab00265
Postby ab00265 » Fri Apr 11, 2014 6:13 am
Can you explain why? If I am just trying to perform a 1 step ahead forecast, I have all the data required to produce a forecast.
Is it something in the GARCH specification that prevents a one step forecast from being run?
thank you
Postby EViews Gareth » Fri Apr 11, 2014 7:30 am
I'm confused - do you have actual data over the forecast period or not? You need actuals to perform a static forecast.
ab00265
Postby ab00265 » Thu Apr 17, 2014 9:15 am
I don't have actual data over the forecast period. But I am only trying to forecast the next blank datapoint.
i.e. I have data up to time t, and want to estimate a data point for t+1.
I would have thought this wouldn't be a problem, since I have data enough data previously to feed into the 1 step ahead forecast.
Postby EViews Gareth » Thu Apr 17, 2014 9:19 am
Post your workfile.
