hi
there is mistake in the publication date of the add-in SVARPatterns published in 15 jan 2014 not 15 jan 2015 (see Add-in Objects).
mistake SVARPatterns published
Re: mistake SVARPatterns published
Also I haven't been able to get the add-in to work on a model that I've estimated already in RATS. It appears to give no output. My short and long patterns were identical with those I used in RATS. Or, perhaps, I've misunderstood the instructions. Is there an example that could be used to check the user's implementation?
There are too many potential cases, so it would be more efficient to see your model and workfile.
Here is the workfile.
- bjornland.wf1
- (33.75 KiB) Downloaded 673 times
If you run the following command:
You'll get the following factor matrix:
bjvar.svarpatterns(shortmat=short,longmat=long,factormat=fmat,estimate)Code: Select all
0.436310 0.000000 0.000000 0.000000 0.000000
0.033299 0.657013 0.000000 8.08E-17 1.07E-16
0.269449 0.221643 2.010689 0.000000 6.97E-18
0.245102 0.043551 0.077802 0.377272 -0.361487
2.118307 2.644614 -0.267502 9.575080 8.140603Re: mistake SVARPatterns published
I did that but didn't get the factor matrix. Perhaps there's another problem, but I'll check if I can replicate your result.
I reinstalled the add-in and replicated your result. There must have been something dodgy about the original installation.
Thanks for your help.
Actually, it was my mistake. EViews has nice string equality functions, but I did not use them. I made the necessary changes, and I am glad to hear that it is working.
