mistake SVARPatterns published
ecofin
Postby ecofin » Wed Jan 22, 2014 6:09 am
hi
there is mistake in the publication date of the add-in SVARPatterns published in 15 jan 2014 not 15 jan 2015 (see Add-in Objects).
terrya
Re: mistake SVARPatterns published
Postby terrya » Wed Jan 22, 2014 12:58 pm
Also I haven't been able to get the add-in to work on a model that I've estimated already in RATS. It appears to give no output. My short and long patterns were identical with those I used in RATS. Or, perhaps, I've misunderstood the instructions. Is there an example that could be used to check the user's implementation?
trubador
Did you use forum search?
Postby trubador » Wed Jan 22, 2014 2:49 pm
There are too many potential cases, so it would be more efficient to see your model and workfile.
terrya
Postby terrya » Wed Jan 22, 2014 3:08 pm
Here is the workfile.
bjornland.wf1
(33.75 KiB) Downloaded 674 times
trubador
Postby trubador » Thu Jan 23, 2014 12:51 am
If you run the following command:
bjvar.svarpatterns(shortmat=short,longmat=long,factormat=fmat,estimate)
You'll get the following factor matrix:
0.436310 0.000000 0.000000 0.000000 0.000000 0.033299 0.657013 0.000000 8.08E-17 1.07E-16 0.269449 0.221643 2.010689 0.000000 6.97E-18 0.245102 0.043551 0.077802 0.377272 -0.361487 2.118307 2.644614 -0.267502 9.575080 8.140603
terrya
Postby terrya » Thu Jan 23, 2014 1:43 am
I did that but didn't get the factor matrix. Perhaps there's another problem, but I'll check if I can replicate your result.
terrya
Postby terrya » Thu Jan 23, 2014 1:51 am
I reinstalled the add-in and replicated your result. There must have been something dodgy about the original installation.
Thanks for your help.
trubador
Postby trubador » Thu Jan 23, 2014 2:26 am
Actually, it was my mistake. EViews has nice string equality functions, but I did not use them. I made the necessary changes, and I am glad to hear that it is working.
Return to “Add-in Support”
