Hello
Do you have any suugestions on how to import a financial series dataset with the following dat structure:
16JAN2012:03:43:42
I tried to import as unstructured and then convert the date variables as below, but i recieve an error:
series datetime = @dateval(@str(lastmodificationdate, "f11.0"),"DDMMYYYYHH:MI:SS")
I have attached a sample in excel
Any support is much appreciated
Neo
Importing trade data with special date format
neophytosk
- eurousdeviews - sample.xls
- (245.5 KiB) Downloaded 333 times
Re: Importing trade data with special date format
If I open that file in EViews 8, EViews automatically recognises the "LastModificationDate" column as a date/time stamp.
You cannot structure the workfile by that series though, since it does not contain unique values.
neophytosk
I am using eviews 7 , is there a way to open the file as you do in v.8?
Also what do you mean by unique values? That some observations occur in the same time?
Thnx
Neo
Thnx
Neo
Yes, some observations occur at the same time, so you cannot use time as an observation identifier.
neophytosk
thnx for the comments.
I imported the data as suggested and use "deal_id" as the identifier (see updated attached sample file) but I still would like to change "lastmodificationdate" to a readable eviews date format as I would like to create a new file with frequency compounding (where I sum up variables for example every 10 minute interval (based on the new date variable)
Any suggestions on how to update the date series?
BR,Neo
BR,Neo
- eurousdeviews - samplev2.xls
- (247.5 KiB) Downloaded 297 times
Post your EViews file.
neophytosk
here is a sample, the original file has 1mln observations so it is too bigto upload
- eurousdeviews - samplev2.wf1
- (17.09 KiB) Downloaded 253 times
In that file lastmodificationdate is already a date format.
neophytosk
perfect,
can i use it now to compund the frequencies e.g at 10 minutes intervals?
if yes how can I do this in eviews?
Thnx
Neo
Thnx
Neo
Create a new page at the frequency you want. Then copy the date over from your existing page to the new page, performing general-match merge frequency conversion. See the User Guide for more details.
