Importing trade data with special date format
neophytosk
Postby neophytosk » Sun Oct 20, 2013 8:19 am
Hello
Do you have any suugestions on how to import a financial series dataset with the following dat structure:
16JAN2012:03:43:42
I tried to import as unstructured and then convert the date variables as below, but i recieve an error:
series datetime = @dateval(@str(lastmodificationdate, "f11.0"),"DDMMYYYYHH:MI:SS")
I have attached a sample in excel
Any support is much appreciated
Neo
eurousdeviews - sample.xls
(245.5 KiB) Downloaded 319 times
Re: Importing trade data with special date format
Postby EViews Gareth » Sun Oct 20, 2013 8:25 am
If I open that file in EViews 8, EViews automatically recognises the "LastModificationDate" column as a date/time stamp.
You cannot structure the workfile by that series though, since it does not contain unique values.
neophytosk
Postby neophytosk » Sun Oct 20, 2013 11:30 am
I am using eviews 7 , is there a way to open the file as you do in v.8?
Also what do you mean by unique values? That some observations occur in the same time?
Thnx
Neo
Postby EViews Gareth » Sun Oct 20, 2013 11:41 am
Yes, some observations occur at the same time, so you cannot use time as an observation identifier.
neophytosk
Postby neophytosk » Sun Oct 20, 2013 1:34 pm
thnx for the comments.
I imported the data as suggested and use "deal_id" as the identifier (see updated attached sample file) but I still would like to change "lastmodificationdate" to a readable eviews date format as I would like to create a new file with frequency compounding (where I sum up variables for example every 10 minute interval (based on the new date variable)
Any suggestions on how to update the date series?
BR,Neo
eurousdeviews - samplev2.xls
(247.5 KiB) Downloaded 287 times
Postby EViews Gareth » Sun Oct 20, 2013 1:35 pm
Post your EViews file.
neophytosk
Postby neophytosk » Sun Oct 20, 2013 1:56 pm
here is a sample, the original file has 1mln observations so it is too bigto upload
eurousdeviews - samplev2.wf1
(17.09 KiB) Downloaded 245 times
Postby EViews Gareth » Sun Oct 20, 2013 3:37 pm
In that file lastmodificationdate is already a date format.
neophytosk
Postby neophytosk » Mon Oct 21, 2013 12:44 am
perfect,
can i use it now to compund the frequencies e.g at 10 minutes intervals?
if yes how can I do this in eviews?
Thnx
Neo
Postby EViews Gareth » Mon Oct 21, 2013 7:43 am
Create a new page at the frequency you want. Then copy the date over from your existing page to the new page, performing general-match merge frequency conversion. See the User Guide for more details.
