stepwise with log of non positive values
bparksb
Postby bparksb » Fri Oct 11, 2013 8:02 am
I am using stepwise regression on a data set with missing values.
Eviews 8 Sept 20 2013 build.
In the list of search regressors, I accidentally entered the log of two binary variables. In Eviews 7, the error message "Log of a non-positive value". In Eviews 8, I get results but I would not classify the results as correct.
Below log(ivy) and log(priv) are logs of binary variables.
Forward selection with log(binary) in the search regressors:
STEPLS(FTOL=0.99,BTOL=0.99) LOG(SCORE) C @ LOG(ACCEPT) LOG(ACT) LOG(ALUM) LOG(ENDOW) LOG(ENDPERSTUD) LOG(ENDPERUND) LOG(GRAD) LOG(IVY) LOG(PRIV) LOG(RET) LOG(S_F) LOG(SAT) LOG(TOPTEN) LOG(TOTENROLL) LOG(UNENROLL)
Dependent Variable: LOG(SCORE)
Method: Stepwise Regression
Date: 10/11/13 Time: 09:11
Sample: 1 202
Included observations: 199
Number of always included regressors: 1
Number of search regressors: 15
Selection method: Stepwise forwards
Stopping criterion: p-value forwards/backwards = 0.9/0.9
Note: final equation sample is larger than stepwise sample (rejected
regressors contain missing values)
LOG(SCORE) = C(1) + C(2)*LOG(ENDPERUND) + C(3)*LOG(TOTENROLL) + C(4)*LOG(ALUM) + C(5)*LOG(S_F) + C(6)*LOG(GRAD) + C(7)*LOG(ACCEPT)
Variable Prob.*
C 0.3815
LOG(ENDPERUND) 0
LOG(TOTENROLL) 0
LOG(ALUM) 0
LOG(S_F) 0.0175
LOG(GRAD) 0
LOG(ACCEPT) 0
R-squared 0.916617
Identical results with .99,.99 rather than .9,.9
Combinatorial with same search regressors
STEPLS(METHOD=COMB,FTOL=0.9,BTOL=0.9,NVARS=7) LOG(SCORE) C @ LOG(ACCEPT) LOG(ACT) LOG(ALUM) LOG(ENDOW) LOG(ENDPERSTUD) LOG(ENDPERUND) LOG(GRAD) LOG(IVY) LOG(PRIV) LOG(RET) LOG(S_F) LOG(SAT) LOG(TOPTEN) LOG(TOTENROLL) LOG(UNENROLL)
Date: 10/11/13 Time: 09:18
Sample: 1 202
Selection method: Combinatorial
Number of search regressors: 7
LOG(SCORE) = C(1) + C(2)*LOG(ENDPERUND) + C(3)*LOG(TOTENROLL) + C(4)*LOG(ALUM) + C(5)*LOG(S_F) + C(6)*LOG(GRAD) + C(7)*LOG(ACCEPT) + C(8)*LOG(RET)
Variable Prob.*
C 0
LOG(ENDPERUND) 0.0003
LOG(TOTENROLL) 0.0001
LOG(ALUM) 0
LOG(S_F) 0.0007
LOG(GRAD) 0
LOG(ACCEPT) 0.003
LOG(RET) 0
R-squared 0.926661
LOG(RET) is in the equation at a pvalue < .9 and yet is not in the forward stepwise. The reported sample and included number of observations are the same and I checked that the 3 missing values of each regression occur at the same observations.
At least as interesting,
STEPLS(METHOD=COMB,FTOL=0.9,BTOL=0.9,NVARS=8) LOG(SCORE) C @ LOG(ACCEPT) LOG(ACT) LOG(ALUM) LOG(ENDOW) LOG(ENDPERSTUD) LOG(ENDPERUND) LOG(GRAD) LOG(IVY) LOG(PRIV) LOG(RET) LOG(S_F) LOG(SAT) LOG(TOPTEN) LOG(TOTENROLL) LOG(UNENROLL)
produces
Date: 10/11/13 Time: 08:59
Sample: 1 202
Included observations: 202
Number of search regressors: 8
Variable Coefficient Std. Error t-Statistic Prob.*
C 3.887912 0.023380 166.2932 0.0000
R-squared 0.000000 Mean dependent var 3.887912
Number of combinations compared: 6435
Somehow included obs is 202 nothing excluded and no variables.
LS LOG(SCORE) C LOG(ENDPERUND) LOG(TOTENROLL) LOG(ALUM) LOG(S_F) LOG(GRAD) LOG(ACCEPT) LOG(RET) LOG(UNENROLL)
Produces
Method: Least Squares
Date: 10/11/13 Time: 09:30
Sample: 1 202
LOG(SCORE) = C(1) + C(2)*LOG(ENDPERUND) + C(3)*LOG(TOTENROLL) + C(4)*LOG(ALUM) + C(5)*LOG(S_F) + C(6)*LOG(GRAD) + C(7)*LOG(ACCEPT) + C(8)*LOG(RET) + C(9)*LOG(UNENROLL)
C 0
LOG(ENDPERUND) 0.0001
LOG(TOTENROLL) 0.6985
LOG(ALUM) 0
LOG(S_F) 0.0002
LOG(GRAD) 0
LOG(ACCEPT) 0.002
LOG(RET) 0
LOG(UNENROLL) 0.1138
R-squared 0.927622
Which is a 8 variable plus intercept, 199 observations, and higher R^2 than the 7 variable plus intercept above. Why didn't combinatorial at least see that model? Why did it produce NO ANSWER?
In Eviews 7 the LOG(PRIV) and LOG(IVY) produce 'log non-positive number'. In Eviews 8, we get, well, I don't know.
Data set available at http://econ413.wustl.edu/pearlmank-v8.wf1
Regressions of interest at T* what WHAT*
See table RESULTS22 if you like.
Bob
Re: stepwise with log of non positive values
Postby EViews Gareth » Fri Oct 11, 2013 8:44 am
Sorry, I'm having difficulty parsing your post. I can't follow what you believe is the issue.
bparksb
Postby bparksb » Fri Oct 11, 2013 5:51 pm
OK
I do a stepwise. Stops at 6 search variables with R^2 .916617
I do a combinatorial (to prove the point) selecting 7 of the 15 search variables.
That produces 7 search variables, adding log(ret) at a PVALUE of 0.00000000 and an R^2 = .926661
So the first stepwise, entering variables at .9 FAILS to enter log(ret) which has a pvalue of 0,00000000
I don't know how to make it more clear to you that stepwise is not working correctly.
Add to that, a combinatorial of 8 produces BLANK!!!!!!!!!!!!!!!! with an R^2 = 0.00000000000000000000
You have to think that is an ISSUE!
I was careful to say that this data is special, that log(ivy) and log(priv) are logs of binary variables and in Version 7 I get 'log of a non-positive number'.
I took two hours constructing and reconstructing the example, being very careful, and writing what I thought were the pertinent points.
Postby EViews Gareth » Fri Oct 11, 2013 5:54 pm
What's the build date of your copy?
bparksb
Postby bparksb » Sat Oct 12, 2013 5:05 am
really, the first two lines of my original post
Postby EViews Gareth » Sat Oct 12, 2013 6:35 am
Sorry, missed that. 32bit or 64bit?
I cannot replicate your results...
bparksb
Postby bparksb » Mon Oct 14, 2013 6:32 am
32 bit XP
bparksb
Postby bparksb » Mon Oct 14, 2013 6:54 am
I should have mentioned STANDARD EDITION, XP service pack 3.
Your stepwise stops at log(ret) but by hand
199 observations, your version stops without LOG(UNENROLL) which enters with pvalue=.11<.99
Postby EViews Gareth » Mon Oct 14, 2013 10:32 am
I'm somewhat confused over which issue you're asking about.
The first issue you mentioned, I believe, was that stepls with forward selection doesn't match the results given with stepls with combinatorial. However when I did it (as my screenshot shows), I obtained the same results between the two. Can you confirm that a) my interpretation of your issue is correct, b) you do not receive the same results between the two methods?
bparksb
Postby bparksb » Mon Oct 14, 2013 11:42 am
Problem #1
Stepwise does not select variables which pass the selection criteria. In my case LOG(RET) was not entered but the pvalue passed the criterion. YOUR case, LOG(UNENROLL), was not entered but passes the criteria.
I used combinatorial to show that in MY CASE the stepwise stopped too soon. I could have done it by hand but thought better to show it via combinatorial - but MATCH is not THE issue although it is an issue.
Issue #2: the combinatorial produces a nothing NO VARIABLES selected
Version 7 produces a 'log of non positive value' for these regressions.
Postby EViews Gareth » Mon Oct 14, 2013 11:48 am
Ah, I think I see your confusion. The key is the warning message printed at the top of the output:
Note: final equation sample is larger than stepwise sample (rejected regressors contain missing values)
In your particular case the number of observations used during the stepwise procedure is 8. Not surprisingly with only 8 observations, combinatorial (forcing 8 regressors) breaks down. Similarly, a forwards routine will stop before the model becomes singular due to a lack of observations.
bparksb
Postby bparksb » Mon Oct 14, 2013 12:27 pm
I am well aware of the warning message. Eviews 7 did not warn, it would not do the regression.
I now see where you say 8 observations (common sample), but why then
Number of observations: 8
Are you saying you use the cross product matrix common sample for ALL the variables, make the selection, and then EXPAND the data set for that particular regression. If so could you please point to a reference? And I would ask that the generic message be replaced with an exact message, something like 'Selection is based on ## observations while the final regression displayed is based on ## observations'. At least then someone like me will not waste time again.
Postby EViews Gareth » Mon Oct 14, 2013 12:55 pm
From the manual:
Following the Stepwise selection process, EViews reports the results of the final regression, i.e. the regression of the always-included and the selected variables on the dependent variable. In some cases the sample used in this equation may not coincide with the regression that was used during the selection process. This will occur if some of the omitted search variables have missing values for some observations that do not have missing values in the final regression. In such cases EViews will print a warning in the regression output.
We'll take your suggestion on board.
bparksb
Postby bparksb » Mon Oct 14, 2013 2:44 pm
Well I looked around at the help files but likely I did not look at the manual but only the help files. My fault I guess.
Again, do you have a references about this method to handle missing values in a stepwise proceedure?
Postby EViews Gareth » Mon Oct 14, 2013 3:11 pm
Help files are identical to the manual.
We do not have a reference.
