If you hit function key F2 in an equation window, an edit field opens. There doesn't appear to be a way to turn it off, except by resetting the View.
Is this the intended behavior?
F2
Re: F2
This is intended behavior. If you press the right mouse button and select Edit+/-. This will turn it off.
We will look into toggling Edit mode with F2 key presses whereas right now it only turns it on.
