Automatic chart update
vytama
Postby vytama » Tue Aug 27, 2013 8:09 am
Hi, I have a few time series in a group. I have charts from the group and I have frozen charts with automatic update. However, the data in the group has changed but chart does not update automatically or if I click update button. Can you tell me what the problem is? Eviews 8 enterprize.
Re: Automatic chart update
Postby EViews Gareth » Tue Aug 27, 2013 8:21 am
Can you provide the workfile?
vytama
Postby vytama » Tue Aug 27, 2013 10:16 am
I noticed that if I update underlaying series in the group, chart updates. My group has transformations (ratio of one series over another), if I change the formula in the group, chart does not update.
u3.WF1
(35.96 KiB) Downloaded 420 times
Postby EViews Glenn » Tue Aug 27, 2013 10:41 am
If I am understanding the question correctly it has to do with what defintions are stored in the updating graph. I believe that the graph object that you created uses the definitions at the time the graph was created. That is, if you have a group
x y x/y
and create an updating graph from it, the graph inherits the definitions in the group at the time it was created. It does not define itself in terms of the group object. Thus, changing x or y will change the values in the graph, but changing the definitions in the group will not.
Note that this behavior allows you to define a temporary group, create an updating graph from the group, and then delete the group.
vytama
Postby vytama » Tue Aug 27, 2013 10:42 am
Ok, thank you.
vytama
Postby vytama » Fri Sep 06, 2013 8:45 am
I have another question on charting. I have multiple pages with series with different frequences. Is there away to select or open charts together from separate pages? Is it possible to store charts from multiple pages on one page dedicated to charts only? Thanks.
Postby EViews Gareth » Fri Sep 06, 2013 9:11 am
Yes, but not if you want them to auto-update.
