Insert data in panel workfile
Fabian2
Postby Fabian2 » Fri Aug 23, 2013 2:55 am
Hi!
I have an existing panel structured workfile. Every observation is identified with year and firm number. How can I insert for example general wage data which is valid for all the firms in one year? I don't want to type in the same number for each observation in one year. Is this possible?
Thanks!
Re: Insert data in panel workfile
Postby EViews Gareth » Fri Aug 23, 2013 7:41 am
Where is the data currently? (The data you want to insert).
Fabian2
Postby Fabian2 » Mon Aug 26, 2013 1:12 am
The data is currently in an excel sheet.
Postby EViews Gareth » Mon Aug 26, 2013 8:02 am
Assuming you have a column in Excel that contains the date (doesn't need to have repeated values), EViews should automatically bring it in for you correctly.
Fabian2
Postby Fabian2 » Tue Aug 27, 2013 2:48 am
See the screenshot for what I meant. A series dependent on year but not on firm number.
I figured out how to do it via links to other workfile pages.
Thank you Gareth for your help!
