Hello :)
The temporal serie is not normal distributed, even when i enter the Log
What solution do you suggest to me?
non normal distribution
Re: non normal distribution
What exactly is the problem with the series being non-normal ?
for the cointegration test, i have 3 temporal series and they are all non normal, it does not matter»?
The series being normal is not of any relevance for cointegration tests. Normality of series is almost never important. Normality of errors sometimes matters, but not often.
Is non normal distribution in cross sectional data a problem?
If it is still existent even after logging data, what can be done?
Thank you
Thank you
Non-normality of data is rarely a problem in large samples unless the departure from normality is extreme.
