non normal distribution
rahma
Postby rahma » Mon May 06, 2013 4:12 am
Hello :)
The temporal serie is not normal distributed, even when i enter the Log
What solution do you suggest to me?
Re: non normal distribution
Postby startz » Mon May 06, 2013 6:59 am
What exactly is the problem with the series being non-normal ?
rahma
Postby rahma » Mon May 06, 2013 8:18 am
for the cointegration test, i have 3 temporal series and they are all non normal, it does not matter»?
Postby startz » Mon May 06, 2013 8:35 am
The series being normal is not of any relevance for cointegration tests. Normality of series is almost never important. Normality of errors sometimes matters, but not often.
rahma
Postby rahma » Mon May 06, 2013 8:38 am
ok, thank you :)
Cabinho
Postby Cabinho » Mon May 27, 2013 9:45 am
Is non normal distribution in cross sectional data a problem?
If it is still existent even after logging data, what can be done?
Thank you
Postby startz » Mon May 27, 2013 10:05 am
Non-normality of data is rarely a problem in large samples unless the departure from normality is extreme.
