How to enter data into a panel workfile.
duynguyen88vn
Re: How to enter data into a panel workfile.
Postby duynguyen88vn » Sat Apr 13, 2013 6:36 pm
please help me! How to enter this data into a panel workfile??????
sheetpanel.xls
(108 KiB) Downloaded 1099 times
Postby EViews Gareth » Sat Apr 13, 2013 9:51 pm
Could you describe it?
duynguyen88vn
Postby duynguyen88vn » Mon Apr 15, 2013 1:25 am
i want to estimate : payout c grownth de cash......
used to random effect model, fix effect model
many thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Postby EViews Gareth » Mon Apr 15, 2013 8:10 am
You'll have to use a program to bring that in as a panel.
In EViews 8:
wfopen c:\temp\sheetpanel.xls byrow range="TANGIBILITY!a1:e101" @rename * *_tang import c:\temp\sheetpanel.xls byrow range="PAYOUT!a1:e101" @rename * *_payout import c:\temp\sheetpanel.xls byrow range="GROWTH!a1:e101" @rename * *_growth import c:\temp\sheetpanel.xls byrow range="SIZE!a1:e101" @rename * *_size import c:\temp\sheetpanel.xls byrow range="EPS!a1:e101" @rename * *_eps import c:\temp\sheetpanel.xls byrow range="TAX!a1:e101" @rename * *_tax import c:\temp\sheetpanel.xls byrow range="DE!a1:e101" @rename * *_de import c:\temp\sheetpanel.xls byrow range="CASH!a1:e101" @rename * *_cash pagestack(page=panel) ?_cash @ ?* rename _* *
duynguyen88vn
Postby duynguyen88vn » Mon Apr 15, 2013 5:47 pm
hic. i used to run Eviews 6. can i run your wf by eviews 6?
can you send to me eviews file of this data?
Postby EViews Gareth » Mon Apr 15, 2013 6:04 pm
You're probably best off just re-arranging the data in Excel.
duynguyen88vn
Postby duynguyen88vn » Mon Apr 15, 2013 6:23 pm
because very large amounts of data . I re-encoded it takes a lot of time!
Can i do it in Eviews 7?
duynguyen88vn
Postby duynguyen88vn » Mon Apr 15, 2013 7:16 pm
Can you send to me eviews of this sheetpanel!!!!!!!!!!!!!! thanks you very much!!!!!!!!!!!
Dxbugs
Postby Dxbugs » Wed Apr 17, 2013 2:46 pm
Hi Gareth,
I was trying to do the exercise by using the second data. I downloaded it and tried in version 7.1.
After doing the stacking in new page, I didn't get the id01 and id02! so I can't continue to the next step: unstacking..variable etc.
What seems to be the problem?
Thanks.
Dx
Postby EViews Gareth » Wed Apr 17, 2013 3:24 pm
In EViews 7, ID01 is VAR01
Dxbugs
Postby Dxbugs » Wed Apr 17, 2013 3:54 pm
Thanks.
I think it is different.
If you look at you posted workfile is says:
c
id01
id02
resid
state
variable
yr
What I got after new stacking:
c
resid
state
var01
variable
yr
there is no id01 and id02?
Postby EViews Gareth » Wed Apr 17, 2013 5:26 pm
Use VAR01
Dxbugs
Postby Dxbugs » Wed Apr 17, 2013 5:49 pm
Use VAR01
Hi Gareth,
attached is my data, formatted the same as your second example. I am new to eviews that is why I am trying to learn the basics..
I really want to know how to convert this excel format to eviews panel data..If possible, can you kindly give me step by step procedure to convert this to panel data? I may actually add some more variables on this later on.
I am using version 7.1
Thanks in advance.
Best.
Dx
Postby EViews Gareth » Wed Apr 17, 2013 7:06 pm
Use "num?" as the stacking id in the page stacking part.
Use "firms var" as the unstacking id, and "var01" as the obs id in the unstacking part.
Qmars
Postby Qmars » Wed Apr 24, 2013 6:03 am
Hello Gareth,
I am using the second type of format on "Re: How to entre data into a panel workfile.". On Panel_STK workfile page, I type alpha var2..... in the command pane to create a new alpha series containing valid names. Once i stroke enter, a messages appears asking if I want to delete "variable" series. By tapping on "yes"tab, the "variable" series disappears but var2 series does not create. Any idea what I am doing wrongly? Thanks
