R package
assaf
R package
Postby assaf » Sun Dec 23, 2012 12:57 am
I have installed R package , and when I try to configure the (AMA ) package to be able of using R package through eviews 7.2 it give me the message : loading required package : rJAVA and the nothing happens and the message last for hours !!!!!
Re: R package
Postby EViews Gareth » Sun Dec 23, 2012 8:34 am
Did you install Statconn?
assaf
Re: R package
Postby assaf » Sun Dec 23, 2012 11:57 pm
Actullay no I didn’t , should I ?
Re: R package
Postby EViews Gareth » Mon Dec 24, 2012 1:19 am
If you don't, R won't talk to EViews. See the manual for more information.
assaf
Re: R package
Postby assaf » Thu Dec 27, 2012 1:24 am
Dear,
I have 2 variables (a dependent and independent) which are almost uncorrelated (-2%), however when I applied fixed effect regression I found on of that the independent significantly affecting the dependent variables at P-value (0.000), what would cause that ? is it possible that there is wrong in my sample ?
assaf
Re: R package
Postby assaf » Thu Dec 27, 2012 3:00 am
I looked in the statistical material and I found that could be related to jointly normally distributed variables, is their any test shows that two variables are jointly normal? Does the interpretation of one variable dependency on other according to the existence of this case ?
assaf
Re: R package
Postby assaf » Mon Dec 31, 2012 6:12 am
is the Statconn a free software or it should be purchased ? i couldn't find it till now !!!!
Re: R package
Postby EViews Gareth » Mon Dec 31, 2012 9:00 am
The EVews manual has details.
http://rcom.univie.ac.at/download.html
