R package
R package
I have installed R package , and when I try to configure the (AMA ) package to be able of using R package through eviews 7.2 it give me the message : loading required package : rJAVA and the nothing happens and the message last for hours !!!!!
Re: R package
Did you install Statconn?
Re: R package
Actullay no I didn’t , should I ?
Re: R package
If you don't, R won't talk to EViews. See the manual for more information.
Re: R package
Dear,
I have 2 variables (a dependent and independent) which are almost uncorrelated (-2%), however when I applied fixed effect regression I found on of that the independent significantly affecting the dependent variables at P-value (0.000), what would cause that ? is it possible that there is wrong in my sample ?
Re: R package
I looked in the statistical material and I found that could be related to jointly normally distributed variables, is their any test shows that two variables are jointly normal? Does the interpretation of one variable dependency on other according to the existence of this case ?
Re: R package
is the Statconn a free software or it should be purchased ? i couldn't find it till now !!!!
