Suppose, for a series of Y, we use the procedure "tramoseats" and get a series Y_sa and Y_sf. Q: How to set parameters in Eviews procedure tramoseats, to satisfy Y = Y_sa + Y_sf?
I tried different combinations of settings, but does not work. For example, Y.tramoseats (opt = "lam = 1 seats = 2", save = "sa sf") Y
Thank You in advance for Your time and assistance.
Use TRAMO/SEATS in Eviews
Re: Use TRAMO/SEATS in Eviews
I'm not sure TramoSeats supports such a thing.
Hello, EViews Gareth!
Apparently Tramoseats must support such a thing, as it is usually the result of the dialog box, which I have attached a picture below.
- tramoseats.png (49.98 KiB) Viewed 7483 times
I don't see it in that screenshot.
Let`s choose the marked settings and click this buttons. Then, we can have the following result: Y=Y_SA+Y_SF.
- tramoseats.png (58.22 KiB) Viewed 7482 times
For monthly series, you can try the following:
y.tramoseats(opt="mq=12 imean=1 lam=1 inic=3 iconce=1 idif=3 iatip=1 seats=2",save="sa sf")Re: Use TRAMO/SEATS in Eviews
Thanks, trubador! It works!
Last bumped by dauren on Thu Nov 01, 2012 10:55 pm.
