Autocorrelation
yoyoo
Autocorrelation
Postby yoyoo » Wed May 23, 2012 2:02 pm
How can I eliminate the autocorrelation to reach Durbin Watson close to 2?
What are the steps to do that?
Thank you in advance.
Re: Autocorrelation
Postby startz » Wed May 23, 2012 3:13 pm
Look at the AR(1) command in the help system.
yoyoo
Re: Autocorrelation
Postby yoyoo » Fri May 25, 2012 8:02 am
I followed the instructions but a message appeared:” Insufficient number of observations”
Attached the snap shots of what I did.
Please help.
Thank you
Re: Autocorrelation
Postby EViews Glenn » Fri May 25, 2012 10:39 am
Hard to say without seeing the workfile. I do note that you appear to have a three-dimensional panel with 2 observations per block. This may or may not be what you want...
yoyoo
Re: Autocorrelation
Postby yoyoo » Fri May 25, 2012 11:20 am
This is the work file.
Are the results change if I use/not use the 3D panel data?
all var.wf1
(143.44 KiB) Downloaded 201 times
Re: Autocorrelation
Postby startz » Fri May 25, 2012 4:52 pm
EViews seems to think the time dimension is your 3rd dimension. You need it to understand that year is the time dimension.
yoyoo
Re: Autocorrelation
Postby yoyoo » Wed Jun 06, 2012 1:41 pm
It worked after I deleted the time dimension.
Thank you indeed for your help.
