Hello!
I followed the example program of bivariate GARCH (1,1), which I found after EVIews 7 installation.
Everything had been clear until Logl estimating process.
I wrote a command:
smpl s1
bvgarch.ml(showopts, m=100, c=1e-5)
And then I got the error:
"Missing values in @LOGL series at current coefficients at observation 2."
Can anybody explain as soon as possible, what should I do?
I attach the workfile that I had just before the command, I mentioned above.
And also full programm for my research.
Bivariate GARCH(1,1). Problem with "logl" - TIME-CRITICAL!!
- 3.prg
- (3.42 KiB) Downloaded 283 times
- before the command.WF1
- (59.06 KiB) Downloaded 214 times
Re: Bivariate GARCH(1,1). Problem with "logl" - TIME-CRITICA
I resolved this problem! I should have set the first observation of a sample "s0" a period after the first observation of a range of all the data; and, of course, then shift "s1".
But, anyway, thank you :)
