Bivariate GARCH(1,1). Problem with "logl" - TIME-CRITICAL!!
errdni
Postby errdni » Thu May 17, 2012 8:12 am
Hello!
I followed the example program of bivariate GARCH (1,1), which I found after EVIews 7 installation.
Everything had been clear until Logl estimating process.
I wrote a command:
smpl s1
bvgarch.ml(showopts, m=100, c=1e-5)
And then I got the error:
"Missing values in @LOGL series at current coefficients at observation 2."
Can anybody explain as soon as possible, what should I do?
I attach the workfile that I had just before the command, I mentioned above.
And also full programm for my research.
3.prg
(3.42 KiB) Downloaded 294 times
before the command.WF1
(59.06 KiB) Downloaded 220 times
Re: Bivariate GARCH(1,1). Problem with "logl" - TIME-CRITICA
Postby EViews Gareth » Thu May 17, 2012 8:20 am
errdni
Postby errdni » Thu May 17, 2012 9:40 am
I resolved this problem! I should have set the first observation of a sample "s0" a period after the first observation of a range of all the data; and, of course, then shift "s1".
But, anyway, thank you :)
