when i try to run TSLS equation, it says that the dependent variable is "not defined".
LN_GDP is the dependent variable, there are 3 explanatory variables and 2 instrumental variables
I input in "equation specification"
ln_gdp c lat_90 lcopen control_of_corruption
in "instrument list"
c lat_90 logfrankrom logem
I am new to eviews and my question may be very simple, but please tell me what to do
TSLS "not defined" notification
Is there a variable called ln_gdp in the workfile?
Re: TSLS "not defined" notification
thank you for your reply!
Yes, there is a variable ln_gdp. It's natural logorythm for gdp per capita for a number of coutries.
Is there something wrong with the name itself?
I'm using eviews 7, by the way
Post your workfile.
thank you for your help, here is the workfile.
i enter the parameters in the equation window as i wrote in my initial post.
- disso - regression variables.WF1
- (14.04 KiB) Downloaded 216 times
The LN_GDP variable has a funny character (it isn't a true _ in the name, it is some weird other character). Rename that series to something else.
I've just renamed it and other variables to eliminate all "_" signs. But it is giving the same error message. I'm starting to think there is something wrong with the data series themselves. I'm reuploading the workfile with the new names. It looks like this now:
C
CORRUPTION
COUNTRY
LAT90
LCOPEN
LNGPD
LOGEM
LOGFRANKROM
RESID
C
CORRUPTION
COUNTRY
LAT90
LCOPEN
LNGPD
LOGEM
LOGFRANKROM
RESID
- disso - regression variables.wf1
- (14.04 KiB) Downloaded 190 times
LNGPD is not the same as LNGDP :D
oh, thank you very much!LNGPD is not the same as LNGPD :D
i can't believe i made such a silly mistake and it cost me so much time.
I am having the same problem. I've checked to make sure _ is not __ and looked at the spelling, but just cant work it out. I am trying to estimate equation lgdp? = c ls? ln? lpr? and eviews says that lgdp is not defined. Can you help?
Nicole
Nicole
- ae coursework.wf1
- (19.71 KiB) Downloaded 186 times
That's probably because in the file you posted lgdp is not defined.
Hi!
I am new to eviews and I am happy I found this forum.
I receive the same `not defined` notification. Both my independent and dependent variables are matrices.
Is it perhaps the reason. If yes, how can I run a co-integration regression on eviews then. In the files below,
fbeta is my dependant variable and rbeta is my independent variable.
I would deeply appreciate your help.
