TSLS "not defined" notification
lalalaguy
Postby lalalaguy » Wed Mar 07, 2012 10:49 pm
when i try to run TSLS equation, it says that the dependent variable is "not defined".
LN_GDP is the dependent variable, there are 3 explanatory variables and 2 instrumental variables
I input in "equation specification"
ln_gdp c lat_90 lcopen control_of_corruption
in "instrument list"
c lat_90 logfrankrom logem
I am new to eviews and my question may be very simple, but please tell me what to do
Postby EViews Gareth » Thu Mar 08, 2012 12:02 am
Is there a variable called ln_gdp in the workfile?
lalalaguy
Re: TSLS "not defined" notification
Postby lalalaguy » Thu Mar 08, 2012 11:26 am
thank you for your reply!
Yes, there is a variable ln_gdp. It's natural logorythm for gdp per capita for a number of coutries.
Is there something wrong with the name itself?
I'm using eviews 7, by the way
Postby EViews Gareth » Thu Mar 08, 2012 11:32 am
Post your workfile.
lalalaguy
Postby lalalaguy » Thu Mar 08, 2012 11:56 am
thank you for your help, here is the workfile.
i enter the parameters in the equation window as i wrote in my initial post.
disso - regression variables.WF1
(14.04 KiB) Downloaded 215 times
Postby EViews Gareth » Thu Mar 08, 2012 12:11 pm
The LN_GDP variable has a funny character (it isn't a true _ in the name, it is some weird other character). Rename that series to something else.
lalalaguy
Postby lalalaguy » Thu Mar 08, 2012 12:21 pm
I've just renamed it and other variables to eliminate all "_" signs. But it is giving the same error message. I'm starting to think there is something wrong with the data series themselves. I'm reuploading the workfile with the new names. It looks like this now:
C
CORRUPTION
COUNTRY
LAT90
LCOPEN
LNGPD
LOGEM
LOGFRANKROM
RESID
disso - regression variables.wf1
(14.04 KiB) Downloaded 190 times
Postby EViews Gareth » Thu Mar 08, 2012 12:34 pm
LNGPD is not the same as LNGDP :D
lalalaguy
Postby lalalaguy » Thu Mar 08, 2012 12:41 pm
LNGPD is not the same as LNGPD :D
oh, thank you very much!
i can't believe i made such a silly mistake and it cost me so much time.
nicoles
Postby nicoles » Wed Mar 14, 2012 12:47 pm
I am having the same problem. I've checked to make sure _ is not __ and looked at the spelling, but just cant work it out. I am trying to estimate equation lgdp? = c ls? ln? lpr? and eviews says that lgdp is not defined. Can you help?
Nicole
ae coursework.wf1
(19.71 KiB) Downloaded 186 times
Postby startz » Wed Mar 14, 2012 1:30 pm
That's probably because in the file you posted lgdp is not defined.
mcvix
Postby mcvix » Tue Apr 02, 2013 6:44 pm
Hi!
I am new to eviews and I am happy I found this forum.
I receive the same `not defined` notification. Both my independent and dependent variables are matrices.
Is it perhaps the reason. If yes, how can I run a co-integration regression on eviews then. In the files below,
fbeta is my dependant variable and rbeta is my independent variable.
I would deeply appreciate your help.
fbeta.wf1
(38.72 KiB) Downloaded 188 times
rbeta.wf1
(38.72 KiB) Downloaded 181 times
