autoregressive panel data model
tumrafael91
Hello, I would like to find out weather it is possible to construct and estimate autoregressive panel data model using eviews, and if it is possible tell me please how to do... Thanks
What do you mean by an AR panel data model?
tumrafael91
Re: autoregressive panel data model
I mean that I have a model
Y(t) = c0 + c1*X(t) +
VOLt = b0 + b2CPI + b3REP + b4EX + b5SMI + b6FIP +et
BASt = a0+ a1VOLt+ ut
then I have pooled panel data by country by days and factors
can eviews estimate this model?
I'm not sure I see the AR component of that model.
tumrafael91
some factors in the first equation are dependent on each other..... one factor cause another
That has nothing to do with an AR model.some factors in the first equation are dependent on each other..... one factor cause another
If you think the left hand side variable causes some of the right hand side variables you may wish to look into instrumental variable methods.
tumrafael91
I understood thanks, and my final question....
Can I use 2SLS having panel data observations
tumrafael91
So as I understood firstly I must create a workfile, import panel data, and the after that construct a system object.......am I right?
You don't need a system object to use the TSLS command.
tumrafael91
but my model is a system of two simultanious equations, and I can t exlude one of them....it will make my model incomplete.....so can i follow the steps that I described above
Perhaps you should show us what you've done and tell us where you've gotten stuck.
