autoregressive panel data model
tumrafael91
Postby tumrafael91 » Thu Jan 19, 2012 5:20 am
Hello, I would like to find out weather it is possible to construct and estimate autoregressive panel data model using eviews, and if it is possible tell me please how to do... Thanks
Postby EViews Gareth » Thu Jan 19, 2012 7:43 am
What do you mean by an AR panel data model?
tumrafael91
Re: autoregressive panel data model
Postby tumrafael91 » Fri Jan 20, 2012 2:54 am
I mean that I have a model
Y(t) = c0 + c1*X(t) +
VOLt = b0 + b2CPI + b3REP + b4EX + b5SMI + b6FIP +et
BASt = a0+ a1VOLt+ ut
then I have pooled panel data by country by days and factors
can eviews estimate this model?
Postby EViews Gareth » Fri Jan 20, 2012 8:39 am
I'm not sure I see the AR component of that model.
tumrafael91
Postby tumrafael91 » Sat Jan 21, 2012 4:40 am
some factors in the first equation are dependent on each other..... one factor cause another
Postby startz » Sat Jan 21, 2012 9:40 am
That has nothing to do with an AR model.
If you think the left hand side variable causes some of the right hand side variables you may wish to look into instrumental variable methods.
tumrafael91
Postby tumrafael91 » Sun Jan 22, 2012 1:15 am
I understood thanks, and my final question....
Can I use 2SLS having panel data observations
Postby startz » Sun Jan 22, 2012 8:16 am
sure
tumrafael91
Postby tumrafael91 » Mon Jan 23, 2012 1:50 am
So as I understood firstly I must create a workfile, import panel data, and the after that construct a system object.......am I right?
Postby startz » Mon Jan 23, 2012 7:29 am
You don't need a system object to use the TSLS command.
tumrafael91
Postby tumrafael91 » Tue Jan 24, 2012 1:58 am
but my model is a system of two simultanious equations, and I can t exlude one of them....it will make my model incomplete.....so can i follow the steps that I described above
Postby startz » Tue Jan 24, 2012 7:26 am
Perhaps you should show us what you've done and tell us where you've gotten stuck.
