TVAR (Threshold VAR)
This thread is about the TVAR Add-in that estimates a Threshold VAR using the R package tsDyn. You will need R to run this Add-in.
Re: TVAR (Threshold VAR)
Upon trying to add it, it gives an error that it's not available!
Sorry, try now.
I`m trying to estimate a TVAR model, but i get the following error: R(for 'test<-TVAR(g, 2, include="const"model="TAR",thhresh=1)') returned an error: evaluation stopped because of an error!
Any idea how to pass this error?
Thanks!
Thanks!
The R-code reported an error. Hard to know what that error is without seeing it.
Hi great people, I'm trying to run TVAR with the new add-in but keep seeing this error message "noexternal connection is open". I've R and I've tried to run tsDyn although I'm not s sure whether I've done the later right (I mean tsDyn).
Can anyone tell me what the above error mean and how to have tsDyn work (if that's the culprit as I suspect it to be)?
Thanks in advance.
Gore
Thanks in advance.
Gore
Sounds like you haven't set up the R connection in EViews properly. Please see the EViews manual for more information on how to do so.
I got the same error like gordeza. I think its because the 'tvar' command cannot handle NA's as inputs. For instance, I tried to estimate a variable in log difference - dlog(gdp), and since the first observation of dlog is an NA it returns an error.
Try to change the sample accordingly and it might work
Question to Gareth - is it possible to get from 'TsDyn' St. dev of the coefficients? and IRFs?
NAs will not (at least shouldn't) cause an error of "noexternal connection is open". They will cause a separate error.
The R code doesn't have standard errors or IRFs :(
I've re-installed everything and now I keep getting the very same error message that Mihaain mentioned early:
"R(for 'testtar<-TVAR(g, 1, include="const"model="TAR",thhresh=1)') returned an error: evaluation stopped because of an error".
Any idea on how to proceed?
Btw, I've Eviews 7.2 running on Windows 7 Ultimate 64 bit.
Thanks in advance!
Thanks in advance!
Could you post your workfile?
Thanks in advance Gareth. Here is the file; which is the data from Tsay 1998 testing and modelling threshold models. I also hope the output displays the threshold.
- testtvar.WF1
- (10.95 KiB) Downloaded 2955 times
I ran the Add-in with those two variables and it worked with 2, 3 and 4 lags.
Somehow it's finally working.
Thanks so much!
Thanks so much!
hello,
I've already installed the program R ,Eviews and its package as well the Add-ins TVAR. However, when i am put the variables and lags and when i click "ok" it shows up a error message " R is not installed, please check your eviews documentantion for instructions on installing in R"... but ive already installed.
Could you help me??
thanks
Yours sincerely,
Scalper
Could you help me??
thanks
Yours sincerely,
Scalper
